嵌入式 > 嵌入式开发 > 详情
MSP430单片机硬件IIC
发布时间:2025-09-15 发布时间:
//MSP430IIC接口是很方便的物件,但是还是有很多人弃之不用,当然有各种原因,但是如果你确实要用IIC接口,而且容许的话,用它还是很舒服的,可能开始不太顺,但是一旦搞通了你会体会到他的好处。
我看了一些网上的程序,有的仍然用模拟方式的思维处理某些环节,比如应答信号。非要追踪”ACK”不可,其实接口已经提供了“NACK”中断,何必非要反向处理呢?事实上,如果在正常传送中出现“NACK”中断,你要考虑更换器件或者考虑系统的稳定性了。
#include <msp430x16x.h>
unsigned char RX_BUF[10];
unsigned char TX_BUF[16];
unsigned char Rece_data[16];
int RX_COUNTER;
int TX_COUNTER;
void Init_IIC(void);
void EEPROM_WriteN(unsigned char mAddr,unsigned char sAddr,unsigned char n);
unsigned char EEPROM_ByteRead(unsigned char mAddr,unsigned char sAddr);
void EEPROM_ReadN(unsigned char mAddr,unsigned char sAddr,unsigned char n);
//USART0中断
#pragma vector = USART0TX_VECTOR
__interrupt void I2C_ISR(void)
switch(I2CIV)
case 2: I2CTCTL |= I2CSTP; I2CIFG=0; break;//无应答
case 10: RX_BUF[RX_COUNTER] = I2CDRB;
RX_COUNTER++;
break;
case 12: I2CDRB = TX_BUF[TX_COUNTER];
TX_COUNTER++;
break;
default: break;
//系统时钟初始化
void INIT_SYSTIMER(void)
unsigned char i;
BCSCTL1 &= ~XT2OFF; //选 XT2
do
IFG1 &= ~OFIFG; //清除震荡器失效标志
for (i = 0xFF; i > 0; i--); //稳定时间
while ((IFG1 & OFIFG)!=0); //如果震荡器失效标志存在,等待
BCSCTL2 = SELM_2 + SELS + DIVS_3; //MCLK时钟源=XT2,SMCLK时钟源=XT2/8
void delay(unsigned int i)
unsigned int j;
for(j=0;j}
void Init_IIC(void)
P3SEL |= 0x0a;
U0CTL = I2C + SYNC;
U0CTL &= ~I2CEN;
I2CTCTL |= I2CSSEL_2; //SMCLK
I2CPSC = 9; //I2C时钟 = SMCLK / 10: 100KH;
I2CSCLH = 0x03; //SCL 高电平为:5 *I2C 时钟
I2CSCLL = 0x03; //SCL 低电平为:5 *I2C 时钟
I2CSA = 0X50;
I2CNDAT = 0x02;
U0CTL |= I2CEN; //I2C 模块有效
I2CIE |= TXRDYIE + RXRDYIE; //Enable TX RX interrupt
//对于FM24L16的写操作 发送N个数据
//16>n>0
//0x50<=mAddr<=0x57 sAddr<16;
I2CSA = mAddr; //页地址
TX_BUF[0] = sAddr; //子地址
I2CNDAT = n; //计数器初值
TX_COUNTER = 0;
while (I2CDCTL & I2CBUSY); //检查模块忙
I2CIFG =0; //中断标志清零
I2CIE |= TXRDYIE;
U0CTL |= MST;
I2CTCTL |= I2CTRX + I2CSTT + I2CSTP;
while ((~I2CIFG) & ARDYIFG); //检查发送结束
//读1个字节
TX_COUNTER = 0; //计数器初值
RX_COUNTER = 0;
I2CNDAT = 1; //1位数据=子地址
I2CIFG = 0; //中断标志清零
I2CIE |= TXRDYIE;
U0CTL |= MST;
I2CTCTL |= I2CTRX + I2CSTT; //置位起始位 发送子地址
I2CIFG &= ~ARDYIFG;
I2CIE |= RXRDYIE;
I2CTCTL &= ~I2CTRX;
I2CTCTL |= I2CSTT + I2CSTP; //接收1位数据后置位停止位
while ((~I2CIFG) & ARDYIFG); //检查接收结束
return RX_BUF[0]; //返回接收的1字节数据
//n=读N个字节,mAddr页地址;sAddr子地址
unsigned char i;
unsigned char k;
unsigned char m=0;
k = sAddr + n;
for(i=sAddr;i {
Rece_data[m]=EEPROM_ByteRead(mAddr,i);
m++;
void SAVE_DATA(unsigned char mAddr,unsigned char sAddr,unsigned char n)
TX_BUF[1] = 0X41;
TX_BUF[2] = 0X42;
TX_BUF[3] = 0X43;
TX_BUF[4] = 0X44;
TX_BUF[5] = 0X45;
TX_BUF[6] = 0X46;
TX_BUF[7] = 0X47;
TX_BUF[8] = 0X48;
TX_BUF[9] = 0X49;
TX_BUF[10] = 0X4A;
TX_BUF[11] = 0X4B;
EEPROM_WriteN(0x50,0x00,n+1);
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
INIT_SYSTIMER();
Init_IIC();
_EINT(); //打开中断
while(1)
SAVE_DATA(0x50,0x00,11);
EEPROM_ReadN(0x50,0x00,11);
delay(10);
单片机应用系统的抗干扰方法
