1:GUI_X_ucos.c文件夹,第80行,修改为:
* GUI_X_ExecIdle()
void GUI_X_ExecIdle (void)
// OS_X_Delay(1);
OSTimeDly(50);//自己修改的
2:GUI_X_ucos.c最后添加以下函数,从GUI_X.c文件拷贝的,工程中不需要添加GUI_X
//下面是从GUI_X拷贝的
* Logging: OS dependent
Note:
Logging is used in higher debug levels only. The typical target
build does not use logging and does therefor not require any of
the logging routines below. For a release build without logging
the routines below may be eliminated to save some space.
(If the linker is not function aware and eliminates unreferenced
functions automatically)
void GUI_X_Log (const char *s) { GUI_USE_PARA(s); }
void GUI_X_Warn (const char *s) { GUI_USE_PARA(s); }
void GUI_X_ErrorOut(const char *s) { GUI_USE_PARA(s); }
工程文件截图如下:
