Renesas公司的RX630系列是32位MCU,工作频率最大为100MHz,100MHz时的性能为165 DMIPS,具有单精度32位IEEE-754浮点,两种类型的乘法和累加器,工作电压2.7V-3.6V,主要用在嵌入式系统.本文介绍了RX630系列主要特性,方框图,RX630系列评估板主要特性与指标,方框图,电路图和元件布局图.
RX630系列主要特性:
■ 32-bit RX CPU core
Max. operating frequency: 100 MHz
Capable of 165 DMIPS in operation at 100 MHz
Single precision 32-bit IEEE-754 floating point
Two types of multiply-and-accumulation unit (between memories and between registers)
32-bit multiplier (fastest instruction execution takes one CPU clock cycle)
Divider (fastest instruction execution takes two CPU clock cycles)
Fast interrupt
CISC Harvard architecture with 5-stage pipeline
Variable-length instructions: Ultra-compact code
Supports the memory protection unit (MPU)
JTAG and FINE (two-line) debugging interfaces
■ Low-power design and architecture
Operation from a single 2.7- to 3.6-V supply
Low power consumption: A product that supports all peripheral functions draws only 500 μA/MHz.
RTC is capable of operation from a dedicated power supply (min. operating voltage: 2.3 V).
Four low-power modes
■ On-chip main flash memory, no wait states
100-MHz operation, 10-ns read cycle (no wait states)
384-Kbyte to 2-Mbyte capacities
User code programmable via the USB, SCI, or JTAG
■ On-chip data flash memory
Max. 32 Kbytes, reprogrammable up to 100,000 times
Programming/erasing as background operations (BGOs)
■ On-chip SRAM, no wait states
32- to 128-Kbyte capacities
For instructions and operands
Can provide backup on deep software standby
■ DMA
DMAC: Incorporates four channels
DTC
■ Reset and supply management
Power-on reset (POR)
Low voltage detection (LVD) with voltage settings
■ Clock functions
External crystal oscillator or internal PLL for operation at 4 to 16 MHz
Internal 125-kHz LOCO and 50-MHz HOCO
Dedicated 125-kHz LOCO for the IWDT
Frequency of the oscillator for sub-clock generation: 32 kHz
■ Real-time clock
Adjustment functions (30 seconds, leap year, and error)
Time capture function (for capturing times in response to event-signal input on external pins)
■ Independent watchdog timer
125-kHz LOCO clock operation
■ Useful functions for IEC60730 compliance
Oscillation-stop detection, frequency measurement, CRC, IWDT, self-diagnostic function for the A/D converter, etc.
■ Up to 22 communications interfaces
USB 2.0 full-speed function interface (1 channel)
CAN (compliant with ISO11898-1), incorporating 32 mailboxes (up to 3 channels)
SCI with multiple functionalities (up to 13 channels)
Choose from among asynchronous mode, clock-synchronous mode, smart-card interface mode, simple SPI, simple I2C, and extended serial mode.
I2C bus interface for transfer at up to 1 Mbps (up to 4 channels)
RSPI for high-speed transfer (up to 3 channels)
■ External address space
8 CS areas (8 × 16 Mbytes)
Multiplexed address data or separate address lines are selectable per area.
8-, 16-, or 32-bit bus space is selectable per area
■ Up to 20 extended-function timers
16-bit MTU2: input capture, output capture, complementary PWM output, phase-counting mode (6 channels)
16-bit TPU: input capture, output capture, phase-counting mode (12 channels)
8-bit TMR (4 channels)
16-bit compare-match timers (4 channels)
■ A/D converter for 1-MHz Operation
Up to 21 12-bit channels, and incorporating 1 sample-and-hold circuit
Up to 8 10-bit channels, and incorporating 1 sample-and-hold circuit
Addition of results of A/D conversion (in the 12-bit A/D converter)
Self diagnosis (for the 10-bit A/D converter)
■ 10-bit D/A converter: 2 channels
■ Temperature sensor for measuring temperature within the chip
■ Register write protection function can protect values in important registers against overwriting.
■ Up to 148 pins for GPIO
5-V tolerance, open drain, input pull-up, switchable driving ability
■ Operating temp. range
–40 degree C to +85 degree C
