单片机小制作时写的一些小程序,在最小系统上运行成功,采用的是中断键盘扫描.
//****键值表如下:
// 1 2 3 4
// 5 6 7 8
// 9 + - *
// / = CLR
#include
#define unint unsigned int
#define unchar unsigned char
sbit P3_4=P3^4;
sbit P3_5=P3^5;
unchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,
0x92,0x82,0xf8,0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e,0x00
#define ADD 10
#define SUB 11
#define MUL 12
#define DIV 13
void delay(unint c){
unint i,j;
for(j=0;j
//**************键盘扫描程序**************
unint keyscan(void)
{ unint n;
delay(1);
if((P1&0xF0)!=0xF0)
P1=0xFE;
if((P1&0xFE)!=0xFE)
if((P1&0xFE)==0xEE)
n=1;
else if((P1&0xFE)==0xDE)
n=2;
else if((P1&0xFE)==0xBE)
n=3;
else
n=4;
P1=0xFD;
if((P1&0xFD)!=0xFD)
if((P1&0xFD)==0xED)
n=5;
else if((P1&0xFD)==0xDD)
n=6;
else if((P1&0xFD)==0xBD)
n=7;
else
n=8;
P1=0xFB;
if((P1&0xFB)!=0xFB)
if((P1&0xFB)==0xEB)
n=9;
else if((P1&0xFB)==0xDB)
n=10;
else if((P1&0xFB)==0xBB)
n=11;
else
n=12;
P1=0xF7;
if((P1&0xF7)!=0xF7)
if((P1&0xF7)==0xE7)
n=13;
else if((P1&0xF7)==0xD7)
n=14;
else if((P1&0xF7)==0xB7)
n=15;
else
n=16;
else
n=0;
P1=0xF0;
return(n);
//LED数值显示程序
void led_display(unint m){
switch(m)
case 1:P2=~0xf1;P0=0xf9;break;//LED以二进制形式显示1
case 2:P2=~0xf2;P0=0xa4;break;//LED以二进制形式显示2
case 3:P2=~0xf3;P0=0xb0;break;//LED以二进制形式显示3
case 4:P2=~0xf4;P0=0x99;break;//LED以二进制形式显示4
case 5:P2=~0xf5;P0=0x92;break;//LED以二进制形式显示5
case 6:P2=~0xf6;P0=0x82;break;//LED以二进制形式显示6
case 7:P2=~0xf7;P0=0xf8;break;//LED以二进制形式显示7
case 8:P2=~0xf8;P0=0x80;break;//LED以二进制形式显示8
case 9:P2=~0xf9;P0=0x90;break;//LED以二进制形式显示9
case 10:P2=~0xfa;P0=0x88;break;//LED以二进制形式显示10
case 11:P2=~0xfb;P0=0x83;break;//LED以二进制形式显示11
case 12:P2=~0xfc;P0=0xc6;break;//LED以二进制形式显示12
case 13:P2=~0xfd;P0=0xa1;break;//LED以二进制形式显示13
case 14:P2=~0xfe;P0=0x86;break;//LED以二进制形式显示14
case 15:P2=~0xff;P0=0x8e;break;//LED以二进制形式显示15
case 16:P2=~0x00;P0=0xc0;break;//CLR
void service_int0()interrupt 0 using 2//采用中断0触发中断的程序
unint last;//第一次键入的数值
unint second;//第二次键入的数值
unint result;//最终运算结果
unint op;//用来存储+、-、*、/操作符键值
last=0;
second=0;
result=0;
op=0;
keyscan();
if(keyscan()>0&&keyscan()<10){//得到的键盘数值是数字的1-9之间的。
if (last==0){
last=keyscan();
led_display(last);//显示第一次按键键值
delay(200);}
else{
second=keyscan();
led_display(second);//显示下一次按键键值
delay(200);
else if(keyscan()>9&&keyscan()<14){//返回的键值为10代表+,11代表-,12代表*,13代表/。
op=keyscan();//将+、-、*、/的键值赋给操作符OP
else if((keyscan()==14) (keyscan()==15)){//返回的键值为15则代表=。
led_display(result);
delay(200);//显示最终的计算结果。
last=0;//清零回复初始状态,当然我们也可以设置一个CLR键来达到此目的。
second=0;
result=0;
op=0;
else if(keyscan()==16){//返回的键值为16代表CLR。
led_display(16);
second=0;
result=0;
op=0;
//***** 四则运算程序*****
if(op!=0&&last!=0&&second!=0)
// 判断是否操作符键以及先后两次的数值键都已经按下。
switch(op){
case 10:result=last+second;if(result>=16){result=result%10;} break;
case 11:result=last-second;if(result>=16){result=result%10;}break;
case 12:result=last*second;if(result>=16){result=result%10;}break;
case 13:result=last/second;if(result>=16){result=result%10;}break;
void main(void){
P0=0xc0;
P2=0xff;//四个LED全灭
P1=0xF0;//处于初始状态,当然随便你设置一个合适的值即可。
P3_4=0;
P3_5=1;
IT0=1;
EX0=1;
EA=1;
while(1);
